code 34 and stutters
Old Feb 8, 2009 | 11:18 AM
purple98haz28's Avatar
my 85 2.8 is throwing a code 34 and it stutters when you hit the go pedal like it bogs then goes and bogs and goes. is there a way to test my maf or to test my vacuum pressure to find out which it may be or could it be something else all together
Old Feb 8, 2009 | 04:52 PM
Re: code 34 and stutters
ok i changed the maf an the code went away. the car seems to run better to. but it does still stutters not quite as bad. how do i check the vacuum. other than that i guess i need to look into ignition... any thoughts
Old Feb 8, 2009 | 04:55 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
have you done anything to clean your car? injector cleaner or seafoam treatment?
Old Apr 13, 2009 | 09:13 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Code 34:
MAP sensor(voltage low)
MAF sensor
Check wires to MAF. make sure its plugged in, check all other wires close to it. other than that it may need a new one.
my other guess was plug wires but you already did that.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
