anybody had experience with this??
Old Feb 10, 2009 | 01:23 PM
auto-x1990RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
Axle/Gears: 3.23 open diff
i found one crazy looking intake, just wondering if anyone's had any experience with it
http://www.shaun.saturnet.net/pics/F...raceparts5.JPG
Old Feb 10, 2009 | 02:05 PM
big john's Avatar
Re: anybody had experience with this??
that is sweet.
Old Feb 10, 2009 | 03:57 PM
pontiacguy1's Avatar
That looks like an old mechanical fuel injection intake manifold. I've never seen one for a 60 degree V6 before. You can take those things and make really great Electronic Fuel Injection systems out of them, of course with a lot of fabrication and tuning.
Converting an old mechanical fuel injection setup over to EFI was really the in-thing for hot rodders and nostalgia types a few years ago. It may still be.
Old Feb 10, 2009 | 04:24 PM
project89's Avatar
that is infact an old ,mechanical injection setup.
once ina blue moon one pops up on ebay
Old Feb 10, 2009 | 10:48 PM
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
well supposedly this is one of 6 ever made full blown racing intakes for the 2.8/3.1 v6. the guy's asking $800 for it
Old Feb 10, 2009 | 11:39 PM
project89's Avatar
while it is a nice piece and by far the best u could could get. its not worth it unless ur prepared to do the following to get the most out of it
#1 switch to a mechanical cam something in the 272 range
#2 convert the intake to efi ( not hard )
#3 build the motor to be able to turn 7-8K on a reg basis
#4 raise compression to atleast 10-1
the nice thing about mechanical injection is u could run methanol or e85 with just a few jet changes,
its very easy to tune but not meant for a street car
to convert it to efi would require pretty much removing the mechanical injector nozzles and having the holes drilled for fuel injectors and having fuel rials made
Old Feb 10, 2009 | 11:43 PM
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
well #3 and #4 on your list are going to happen. i want this engine to be one of those rare N/A sixxers that make a good amount of power. the car is my auto-x/track/dd car (though it won't be my dd for long), so it sees quite a bit of high rpm.
Old Feb 13, 2009 | 12:12 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Looks like a Hilborn system that you used to see in the 60's/70's... get some chrome Hilborn 'trumpets' to go on it and it will look totally trick!
Old Feb 13, 2009 | 01:44 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Can't be that old if it fits a 60* V6
Old Feb 14, 2009 | 09:37 AM
syntax terror's Avatar
I would check isn't that intake for the gen ll aluminum heads ?
Old Feb 14, 2009 | 10:22 AM
project89's Avatar
good eyes man dinotice that
heres what that setup would look like all together on a motor
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
91 SrS
Oct 7, 2015 04:32 PM
jaridjohn
Oct 5, 2015 07:01 AM
mfp189
Sep 27, 2015 09:25 AM
