junk yard parts
Old Feb 15, 2009 | 10:24 PM
backgammon7's Avatar
Car: '86 SC
Engine: 2.8
junk yard parts
so why dont we make a list of cars that have parts that could desirable
to thirdgen owners
I.E. cars that came with turbos, centrifigual supercargers, better brakes (that would fit) anything that a guy could want or need
Old Feb 20, 2009 | 11:42 PM
jon 89 RS's Avatar
Car: 89 camaro rs
Engine: 2.8L
Re: junk yard parts
I think that would be interesting and helpful, so how about it anybody out there know of anything specific?
Old Feb 20, 2009 | 11:51 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: junk yard parts
many S10s came with a similar V6. they had TBI instead of MPFI. i know basically nothing interchanges on the FWD engines.
Old Feb 21, 2009 | 04:30 AM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Re: junk yard parts
sillouet van not sure of spelling it has a 3.1 v6 identical to a 2.8...fiero has a 2.8 in some of those and 3.1.pontiac 6000,blazer with a v6,buick has one ..not sure on model have to find out..
Old Feb 21, 2009 | 04:22 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
Re: junk yard parts
The GMC Jimmy has a 2.8/3.1 as well.
But I don't know what would really work. I'm in the process of finding a better throttle body and other cheap parts from other cars from junk yards/pull-a-parts. With the economy these days, it's getting harder and harder to buy parts. Some of the things I want aren't even top of the line performance and cost around $400! (ie exhaust). It's tough if you don't know how to fabricate yourself.
Old Feb 21, 2009 | 05:44 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: junk yard parts
1. ANY (FWD or RWD) MFI 2.8 or 3.1 for fuel injectors. Beware that these may be partially or fully clogged. Any 3100 or 3.4 will have fuel injectors too big for 2.8 and 3.1 engines and throw codes.
2. Any HEI system with distributor ignition and a module inside the dizzy, for the modules (which may or may not be good... do this at your own risk.) Beware of FWD 4 bangers, as these have the dizzy at the most awful place to try to reach it... at the back, down low, under the intake manifold.
3. Anything with a MAP sensor for 3.1 cars... the MAPs are easy to remove and are good to have ($50+ a pop, similar to fuel injectors).
4. Any V6 for IAC, and TPS. (edit) My fav j/y pulls the IAC, TPS, and CTS from a lot of their cars, bags them up, and sells them for $10. Well, at least that's what they USED to charge. (I haven't needed that stuff in about 3 years now)
5. Ford (yes, I know I'm bad for saying this... ) fuel injectors and possibly some throttle bodies, but you'll need an adapter for the TB's.
6. How's about 3.4 93-95.5 F-bodies, 3100, 3400, and the new 3500 cars for top end swaps?
7. Almost forgot one thing. Anything with a 2.8 for 2.8 owners. The ECMs are interchangeable as long as they are 302's, and they are all under the dash. Anything with the PCM under a cover (with integrated electrical center), on the passenger's side of the engine bay, at the front of the wheel well, is to be passed by, as these are not interchangeable except for the MEMCAL in some cases.
Someone else can chime in about turbos and that stuff... This is the general repair stuff I watch out for when I go to the yard.
TheJoeY88
Dec 31, 2016 07:30 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
bbernardo94
Aug 19, 2015 05:25 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
