confusing problems with ma 3.1
Old Feb 16, 2009 | 04:14 PM
primer91'bird's Avatar
Car: 91' firebird
Engine: 3.1l LHO
Transmission: 700-r4
alrighty now...i got sum problemos...does anybody no wats wrong here...now when i start my car it starts up fine but shuts off after like 5 seconds so i crank it again and starts up and stays on(it does this alot everytime now).now after i cranked it for the second time and stays on,everytime i shift the car into drive or reverse,the car stalls.the way i prevent the car from stalling after i shift it is i press the gas while in park and then shift it while it revs down...but when i stop at a stop light it stalls unless i keep my foot slightly on the gas to keep the engine reving while my foots on the brake and its good.and when i drive it and then when i put it in park and leave it running it stalls also....my car loves to stall...now about a couple of months ago my car shut down on me while i was driving so i replaced the ignition module,spark plugs,wires,rotor button and got it 2 run again but just hasnt been the same...new battery also.
Old Feb 16, 2009 | 05:36 PM
Car: 91' firebird
Engine: 3.1l LHO
Re: confusing problems with ma 3.1
also i was told 2 change my IAC but i got like 5 from the junkyard and tried them all and didnt help one bit.
Old Feb 16, 2009 | 08:20 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Snag a couple of MAP sensors from your fav junkyard and see what happens... It's either that, or the vac line to it is broken or clogged, or you have a vacuum leak elsewhere.
RazorN8
Jan 7, 2022 11:44 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
