Replacement fan question.Anybody?
Old Feb 16, 2009 | 06:39 PM
Bruce91RS's Avatar
My fan "housing" is warped/not round.The fan will not spin because it hits this"housing"that bolts to the fan shroud.I would like to get a replacement one.GM is way to expensive.And the housing is discontinued.They only have the fan blades and fan motor.Does anyone have one for sale?or does anyone know of another GM car that uses the same fan and housing?I dont think theres any in the V6 Camaro/ Firebirds at the yards near me.Or should i heat this one up and try and fix it?Its a single fan not a double.
Old Feb 16, 2009 | 07:33 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: Replacement fan question.Anybody?
i'm putting in a carquest brand fan. its universal.
Old Feb 16, 2009 | 08:23 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check to see if your radiator support is bent. Mine did the same thing due to bad jack placement and I trimmed the fan blade so that it works...
Oh, and any 3rd gen with a single fan has the same shroud. The upper radiator support is not a shroud...
Old Feb 18, 2009 | 10:03 PM
87InRecovery's Avatar
Car: '87 Camaro Sport
Engine: 3.4L w/headers, Crower & Hypertech
Transmission: 700R4, B&M Shift Kit
Axle/Gears: ?
Fan housing is warped? Forget about it!! Just order a replacing fan. "Hayden" is a good inexpensive replacement. Go to summit website. Just bought a nice one that runs $150 and it uses the straps that run through the radiator. Good deal and more effective for cooling.
Old Feb 23, 2009 | 04:54 PM
Bruce91RS's Avatar
found a stock one that works , at the local u pull it for 17.00 bucks. off of a car just like mine. thanks for everyones imput.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
