91 3.1 camaro wierd error code
Old Feb 17, 2009 | 01:58 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
I have a 180 degrees thermostat, so my temperture stays there as long as im driving the car.
now every tie I stand in trafic and my temperature reaches 197 degrees the check engine light comes on and stays on until my temparture falls back under 185 degrees.
anyone has an idea what this could be ?
Old Feb 17, 2009 | 09:21 PM
nd4spd42085's Avatar
Car: Formula/RS
Engine: 5.7L/60 degree
Transmission: both 700r4
Axle/Gears: 2.73 lsd and 3.23, respectively
Re: 91 3.1 camaro wierd error code
reading the codes would be a good start....
use the paper clip trick if you don't have a code reader...
Old Feb 17, 2009 | 09:59 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
OK you peaked my interest
So I grabbed my Camaro manual and I'm going to blind bet that it's a code 14/ Engine overheating.
Old Feb 18, 2009 | 12:04 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
but the temp of the normal thermostat is a 195 degree thermostat,
the fan comes on standard at 227 degrees or something.
Old Feb 18, 2009 | 09:25 AM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
I know but that is that is the only one I could find with temp that looks like what you said but like nd4spd42085 said get the code read and you'll know for sure.
Old Feb 18, 2009 | 09:58 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
think you guessed right, my waterlevel was Low due to having a radiator leak in the top of my radiator.
Old Apr 8, 2009 | 12:34 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
ok, completely new radiator, filed it up with water, and still have the weird error. between 188 en 200 degrees I get an error code when I'm standing still in trafic.
when I'm driving and the temp goes under 188 degrees, the error goes away again.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
