2.8 project
Old Feb 18, 2009 | 03:35 PM
sienaz 86 2.8's Avatar
Car: 86 firebird
2.8 project
i have a 89 complete 2.8 to start with but i want to rebuild it with a little something extra ive found a set of aluminum 3.1 heads with a valve job and ive been given 3 sets of 2.8 pistons 2 9:1 and 1 set of 12:1 compression but there are so many directions i can go between turbos and high compression and engines (have a few 350s and a 400) but i would like to keep my v6 for some reason so does anyone have some input on a direction
Old Feb 18, 2009 | 05:05 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: 2.8 project
I would look at the stickies if you haven't already...this one in particular --> LINK
I assume you have a set of FWD heads...and its not just as easy as slapping them on your 2.8. Im also not really sure how the 2.8 pistons will go with the FWD heads. I cant remember, at this junction, if the 2.8 pistons have a deeper dish that the 3.1...but I know that stock 3.1 pistons with FWD heads throws the CR threw the roof...so to speak.
Any pictures of the heads in question?
Old Feb 18, 2009 | 05:41 PM
Car: 86 firebird
Re: 2.8 project
well it turns out you're rite here are the heads and pistons i have its a shame to because the heads are nice with a 3 and 4 angle valve job and everything but what direction do you guys suggest from here do i swap intakes or take those 2.8 heads on the left and clean them up they are brand new just rusty from being in a basement forever
Old Feb 18, 2009 | 05:49 PM
Car: 86 firebird
Re: 2.8 project
and i see you have the 3.1 intake on yours ... have you gotten it together and running if so that was my original plan with the turbo how do you like it
Old Feb 19, 2009 | 03:28 PM
grimmcs's Avatar
Car: 91 Camaro
Re: 2.8 project
For my project I am using the 3x00 heads with custom forged pistons. And unfortunately Its not running yet...The guy who that's fixing the rust and painting my car is taking his sweet old time But I "should" have everything for when I drop the engine in.
Old Feb 19, 2009 | 09:05 PM
Car: 86 firebird
Re: 2.8 project
ive found a gta near by for 1500 but idk ive put countless hours into mine and would swap the tpi 305 for a 350 so its really not worth it so im back to the v6 modding ... anyway in order to make those heads work i need a 3.1 intake?? and will it all be plug and play?
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
usafirebird
Sep 29, 2015 11:58 PM
92projectcamaro
Sep 29, 2015 07:07 PM
