2.8 liter valve adjustment
Old Feb 25, 2009 | 08:06 PM
mongoosekeith's Avatar
how hard is it to do this???
i'm sure i could figure it out but just curious how hard it is to do
Keith
Old Feb 26, 2009 | 07:36 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 2.8 liter valve adjustment
1. Set engine to TDC #1.
2. Undo ALL rocker nuts until they can be turned by hand with a 15mm deep socket.
3. Remove pushrods and clean the crap out of them until they are no longer greasy on the outside. Reinstall.
4. With one hand on the pushrods for the closed valves (you will know which ones are open based on pushrod height), tighten down the nuts while pulling on the pushrods by hand in the up/down direction until the pushrod can no longer move vertically.
5. Tighten rocker nuts 1/4 turn more.
6. Turn engine over until #4 cylinder is at TDC (one crank revolution).
7. Tighten remaining nuts in the sequence described in step 4.
You're done!
Old Feb 26, 2009 | 08:01 PM
can this be done with the motor in the car???
Old Feb 27, 2009 | 05:40 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Absolutely!!
Old Feb 27, 2009 | 02:23 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Just be sure to mark the WIDE slot in the crank pulley damper with wite-out or something like that so you know when you're at TDC. The TDC mark on the timing scale is the deep V, IIRC.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
snakeshooter
Sep 7, 2015 11:13 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
