3.1 NO SPARK
Old Mar 7, 2009 | 02:16 AM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
3.1 NO SPARK
i have a 90 3.1 with 206000 miles on it. i was driving down the road when all of the sudden my car just shuts off. i can hear the fuel pump and the engine will turn, but after hooking up a timing light i see that there is no spark. i tested the ignition control moduel and the pick up coil, and i also have power from the ingition switch. i also replaced the ingnition coil. the wires, plugs, cap, and rotor are fairly new, so i am confused as to what it might be. any input would be greatly appretiated. thanks
Old Mar 7, 2009 | 11:27 PM
Car: CAMARO RS
Re: 3.1 NO SPARK
I just replaced the computer and it is still not working
Old Mar 7, 2009 | 11:43 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: 3.1 NO SPARK
Worst case scenario might be your timing chain. Mine had about the same mileage on it when the chain broke - more like the nylon teeth wore off the gears and the chain fell off. I was idling in the driveway when the car died and wouldn't restart, engine would turn but not fire up. Easy check is to pull the distributor cap and turn the engine over, if the rotor doesn't turn, the camshaft (driven by the timing chain) isn't turning.
Old Mar 8, 2009 | 08:50 AM
Car: CAMARO RS
Re: 3.1 NO SPARK
Wouldnt i still have spark coming from the coil hook a spark plug up to it
Old Mar 8, 2009 | 11:44 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 3.1 NO SPARK
You forgot one thing in your replace-it list. Your ignition module is probably dead, and that is why you don't have any spark.
The timing chain could be at fault, but I seriously doubt it. With the cap off, have someone crank the engine. If the rotor doesn't spin, well, the chain broke.
:edit: Does the engine sound any different than normal when you crank it, like sort of a high-pitched whine? That's another indicator of not having any compression due to a bad timing set. 206K means it's time for a new one (about every 100-150K is the norm to replace it).
Old Mar 8, 2009 | 01:52 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: 3.1 NO SPARK
did you replace the coil before or after the car shut off? That is classic, textbook coil failure you describe. I've had a brand new hypertech coil go up in one month.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
