Releasing Fuel System Pressure problem
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
I'm trying to replace my fuel filter, but when I pull out the fuel pump fuse, like the manual says, it doesn't run out of fuel like it's supposed to, like the pump still works. How do I get it to release the fuel pressure?
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Re: Releasing Fuel System Pressure problem
Tank off the fuel cap. It will release all of the take pressure.
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
if it is a 2.8 look at back of intake there is a little valve stem looking thing called a strader valve that will release all pressure off of the lines..be carefull it will squirt gas out ..so make sure motor is cold
Car: 2006 GTO
Engine: LS2
Transmission: M6
I guess I'll have to try all three. If none of them seem to work, I'll just try and syphon all the fuel out.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You have to disconnect the 2 wire oil pressure switch (at the oil filter) as well, otherwise the engine is going to run, regardless of whether the fuel pump relay is plugged in or not, when the oil pressure gets high enough. And yes, do expect a bit of a mess with the filter.
Car: 2006 GTO
Engine: LS2
Transmission: M6
Thank you everyone. I got the fuel filter changed, well, my dad had to finish it because gas splashed into my eye! The "confidence chamber" in boot camp didn't hurt anywhere near that.
Yeah, I've been having problems with my camaro. It's been stalling, rough idle, fuel pressure issues (fuel filter replaced fixed that, old one was 10+ years). Runs a little better now. Still having stalling and rough idle issues. Working on fixing those soon!
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Next time pull both injector fuses that will kill the fuel pump then reliese the pressure at the schrader valve . Not as much mess or fuss to do the change then.
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
