engine dead cylinder
Old Mar 12, 2009 | 07:04 AM
ChevyCamaro1990's Avatar
Car: Camaro RS
Engine: 3.1l v6
Ok so i have been doing some work on my 3.1l v6 and its almost ready for the roads but the only problem is its running on 5 cylinders the number 1 cylinder is dead the plug wire at the cap has 17-18 kV down closer to the plug the wire on has 12-13 kV which means the wire is still doing its job. but i wasnt sure were to start to illiminate the problem. i think im going to start with the plug and see if the gap is wrong causing the wire to illiminate some of the voltage. can i get some other ideas to try to illiminate this dead cylinder.
Old Mar 12, 2009 | 10:09 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: engine dead cylinder
i would just change the plug. it could be cracked or the electrode could be burnt off.
i had a simmilar situation a few weeks ago. found the electrode burnt off on nr. 1 plug.
chnaged the plugs and wires and reset the timing. fixed now.
Old Mar 13, 2009 | 07:03 AM
Car: Camaro RS
Engine: 3.1l v6
kk thanks for the input
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
