1.6 Rockers
Old Mar 18, 2009 | 07:10 PM
thebufenator's Avatar
Car: Firebird - Camaro
Engine: 2.8L - 6.3L
Axle/Gears: 3.42 - 3.23
1.6 Rockers
SO I've done a search, and I cant find out how much of a boost 1.6 rockers will give to an otherwise stock 2.8 V6.
I hope to be able to get Pacesetters+catback done sometime soon, and wanted to add the 1.6 rockers to help.
How much do the rockers actually help?
I may end up doing them before the exhaust.....will I actually feel the difference?
Old Mar 18, 2009 | 08:21 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: 1.6 Rockers
Well it might extend the rpm range and make it rev more freely, but you probably won't see much of a gain. You'll get more out of the headers.
Old Mar 18, 2009 | 09:23 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Re: 1.6 Rockers
You can do the 1.6 rockers - although I believe the studs need to be changed from metric to SAE. Also, I believe you will need a valve cover with more clearance.
1.52 roller tipped rockers work quite fine for these engines and as mentioned above, go with headers and add in a CAI.
Old Mar 18, 2009 | 10:17 PM
bl85c's Avatar
Car: '85 maro
Re: 1.6 Rockers
I have a pair of fiero valvecovers that'll give you the clearance you need. Just collecting dust for about a year now.
Old Mar 19, 2009 | 12:38 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: 1.6 Rockers
1.6 rockers and stock valve covers with no problems. Just make sure that you adjust the valves right the first time.
Old Mar 21, 2009 | 05:19 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: 1.6 Rockers
im guna fit 1.6 rockers, i expect only 10hp max, but increased drivability, that would be the main point.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
slowsi
Oct 18, 2015 08:49 PM
Jorlain
Oct 8, 2015 01:57 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
