S10 Block and Heads?
Old Mar 18, 2009 | 08:28 PM
RS90CAMARO's Avatar
I recently got a 1986 s10 2.8L TBI that had blown a head gasket. When I torn down the motor I found that ya the head gasket was blown but it also has 2 spun piston bearings so the crank is toast. It did not spin any bearings on the mains so it looks like the block is ok. My questions is can I use this block and heads on my 1990 3.1 camaro. I remember reading something about oil holes and valve sizes but I cant find it now. Is the difference between the 2.8 and 3.1 just the crank, pistons and rods?
Old Mar 18, 2009 | 10:24 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: S10 Block and Heads?
There's a few other small differences, but basically the only difference is the crank, rods & pistons. Do a double check on the main sizes, I think the early small main blocks may have been carried on into '86 s10's. Won't be compatible if that's the case.
Old Mar 18, 2009 | 11:25 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
I thought 2.8 and 3.1 pistons are the same. As in, a 3.1 is just a stroked 2.8....
Old Mar 19, 2009 | 07:33 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Somewhere in 85-86(I dont know the exact time) the 2.8 went from having small mains to the larger mains that are in the 85/86+ 2.8s and 3.1s. As for the difference between the 2.8 and 3.1...the pistons are what is different.
Jake_92RS
Jan 28, 2020 10:37 PM
MoJoe
Sep 24, 2015 09:12 PM
Ducati900ss
Sep 2, 2015 09:05 AM
gixxer92
Sep 1, 2015 04:32 PM
lakeffect2
Aug 23, 2015 08:44 AM
