7004r
Old Apr 4, 2009 | 08:28 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
7004r
will a 4x4 700r4 fit in the camaro
Old Apr 4, 2009 | 09:20 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: 7004r
Dimensionally, yes, it should be the same size and bolt up to the car....
but what to do with the front driveshaft...... *evil grin* I've been down this road before.
Old Apr 4, 2009 | 09:38 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: 7004r
ok whats that mean i need a new tranny so i can somke my cuzs z28 agin
Old Apr 5, 2009 | 08:21 AM
Car: 1991 Firebird
Re: 7004r
I've looked this over a few times because I want to make my car all wheel drive.
Do you have a front transfer case? 'cause if not, your 4x4 transmission is going to be semi-useless.
Try and find a rear wheel drive one. They should be cheaper.
Old Apr 5, 2009 | 01:13 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 7004r
IDK... It could be possible that all of the 700R4s came from the factory with the same gear ratios. Either way, all you have to do is get rid of the transfer case adapter and install a tailshaft housing from an Fbody. All it is is 4 bolts and an o-ring gasket, along with swapping your VSS in from your existing 700R4.
Bstrang6
Sep 28, 2016 04:58 PM
Warnd
May 2, 2013 07:40 PM
dsterling@roche
Oct 29, 2010 01:31 PM
drivera
Jan 28, 2007 09:41 AM
Dick1234
Feb 25, 2002 05:42 PM
