Need Help With My 2.8L MPFI
Old Apr 8, 2009 | 11:47 PM
Trick186's Avatar
Car: 89 Camaro RS
Engine: 2.8l MP
Transmission: 5 speed Manual
Hi everyone im new here. This is actually my first post. I recently just bought an 89 Camaro RS It has the 2.8L MPFI V6 engine in it. WEll come to find out the engine is pretty messed up. I got oil shooting into my throttle body and intake. I believe i also have a crack in the block but not sure. All i know is im leaking coolant and the car keaps overheating. I have replaced everything like the radiator,water pump, thermostat and all the hoses so its none of that stuff. So now i decided to just buy a new rebuilt engine. The problem i am having is i cant seem to find a 2.8L engine anywhere where i live. According to everyone i talk to the engine is rare and hard to find. So my question is what other engine can i stick in my car that easy east to find? Can a 4.3L from a camaro fit in the car with out changing much. I want an engine that will take the least amount of changes and work to put in. So can you guys please help me and tell me what engines will be the easiest to come buy and fit directly back into the car. A 3.1, 3.4, 4.3 engine? What cars have the engine that i can use?
Old Apr 9, 2009 | 06:44 AM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: Need Help With My 2.8L MPFI
A 4.3 is a 90* motor, the 2.8/3.1/3.4 are all 60* motors which are all direct replacements.
Old Apr 9, 2009 | 07:41 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
What he means to say is that the transmission bolt pattern at the flywheel end of the engine is different on the 2.8 than it is for the 4.3. The 2.8 has what is called an FWD bolt pattern (nearly ALL FWD engines GM uses have the same bolt pattern), and the 4.3 has the SBC/BBC style bolt pattern, being that it is specific for an RWD platform (trucks, mostly).
Either way, have you looked at eBay? I've seen either brand new or freshly rebuilt engines on there a lot, both 2.8, 3.1, and 3.4's. Not cheap, but all you need to add is your coverings and intake, and you're good to go.
Old Apr 9, 2009 | 10:59 AM
Trick186's Avatar
Car: 89 Camaro RS
Engine: 2.8l MP
Ok so i found a 3.4l Engine out of a 93 camaro. Does this work in my car? If im understanding correctly it should fit perfectly right?
Old Apr 9, 2009 | 11:01 AM
Trick186's Avatar
Car: 89 Camaro RS
Engine: 2.8l MP
Sorry guys i jsut read the engine swap info at the top. It answered my question for me. Didnt mean to waste anyones time. Still new here. But next time i start a thread i will research some stuff better before hand to make sure the question i have hasnt already been answered
bplessy
Sep 30, 2015 12:14 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Springster
Sep 13, 2015 01:38 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
