Replacing Oil Pump
Replacing Oil Pump
I am going to be replacing my oil pan and I was thinking while I was in there I would replace the oil pump and pickup. The oil pan is smashed pretty good and I wonder if it may of bent the pickup.
Anyway, what goes into replacing the oil pump? Mostly I am worried about installing the pickup properly so I know I have clearance, etc. From what I've read it's pretty simple, but sometimes pretty simple isn't so simple, as they mention nothing about the pickup.
Any advice?
Thanks,
Douglas
Any advice?
Thanks,
Douglas
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Replacing Oil Pump
Its pretty straight forward. Pull the pan, pull the dizzy, throw your new pump assy in, and throw it back together. The pan is a PITA to get out. I had to disconnect my exhaust and lift the engine a good few inches to get the pan out from around the pickup and crossmember.
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:52 PM
