EST engaged/disengaged
Old May 13, 2009 | 05:53 PM
Poptart's Avatar
Car: '91 Firebird
Engine: V6
I set the timing a few a days ago back at 10* from god knows where it was before (thanks to a loose dizzy hold down.). My question is concerning the EST bypass. On the hood instructions it said to disconnect it, time it, then reconnect it. I did all of this then I was curious so I checked the timing after plugging the wire back in. The timing was about a half an inch above the last timing notch. I take it this isn't normal for idle. Any possible causes for this?
Old May 13, 2009 | 07:14 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: EST engaged/disengaged
If you rechecked the timing after you reconnected the EST bypass, then that's normal. That's the ECM controlling the timing at idle, not the base setting used in a failure of the system.
However, if you can't set the timing because it all of a sudden jumps to the advanced position (without the bypass reconnected or having moved the dizzy at all), then you have a problem with the module (I still have that module as a backup because it DOES work, but it's kind of screwy).
Old May 14, 2009 | 01:45 PM
Poptart's Avatar
Car: '91 Firebird
Engine: V6
Alright. So the base idle setting while in bypass will not be the same as the idle setting while the computer is controlling it.
Ok, looks as if everything is working nicely then. Thanks a bunch.
db057
Apr 28, 2019 07:45 AM
L98GTA87
Oct 19, 2015 10:43 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
pacoelrapido
Sep 11, 2015 02:41 PM
1992Vortec
Aug 31, 2015 08:05 PM
