stock fuel pump?
Old May 21, 2009 | 08:18 AM
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
stock fuel pump?
i have a 1992 camaro with the 3.1l. my fuel pump is dead is there a way to get to the pump with out dropping the tank completely?
Old May 21, 2009 | 11:23 AM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: stock fuel pump?
cut a hole. search will show you pictures and measurements where to do it.
Old May 22, 2009 | 09:06 AM
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
there isn't one some where there already..??? if not i will be taking it down. i was asking because the tank is full of gas.
Old May 27, 2009 | 04:37 PM
davidopliger's Avatar
Car: 1991 Camaro RS
Engine: :( 3.1
syphin (sp) the gas out. and just drop it. its a weak uni body already so cutting anything will weaken the car even more. . one easy thing would be to cut ur exhaust off near the rear end somewhere. that helps..
Old May 27, 2009 | 05:25 PM
sloick's Avatar
Car: Many
Engine: Several
cutting a hole wont weaken it. if youre worried about weld or pop rivet a patch.
Old May 28, 2009 | 08:35 AM
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
i have an after market exhaust so don't need to cut anything. just have to get to it this weekend i guess thanks!
Old May 28, 2009 | 09:06 AM
entrig00's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6
Transmission: t-5
Hey I had the same problem and dropped the fuel tank. This can be pretty tuff. When I did drop it I noticed that the previous owner had made a cute out to the trunk already so I was pretty p*ssed. A lot of people here will say that its not the best thing to do but hey its your ride and it will save you a lot of time....trust me.
Well enough of me going blah blah blah...
Did a search for you so a thank you is all I'd like...jk. Just click the link below and check it out...good stuff to learn and try.
https://www.thirdgen.org/forums/sout...-get-fuel.html
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
