Wiring the Fuel pump relay connector.
Old Jun 2, 2009 | 12:36 PM
xenocide21's Avatar
Car: 1985 Camaro Coupe
Engine: 2.8L V6
Transmission: 4 Spd Auto
Axle/Gears: No damn clue.
I had a bad short in the relay connector, and i cut it off, stupid me i didnt think to write down which color goes where. there is an orange, dark green, black w/ white stripe, tan and an orange with a white stripe, the solid orange is a thick 10 gauge wire i believe, the other orange one is a thin wire. can anyone pop the hood of their camaro and tell me the order in which these wires go? starting from the key to the flat end of the connector. Thanks!
Old Jun 2, 2009 | 08:42 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Wiring the Fuel pump relay connector.
A B C D E
A is the tan wire out to the fuel pump
B is the black/white ground wire
C is the dark green/white switching wire from the ECM
D is the small orange test wire
E is the big orange power in wire from the fuse bolted to the frame rail.
If someone doesn't let you know which side the key is on by tomorrow, I'll post it up (it's not in my repair manual for some reason). But, I think that the big orange one is farthest from the key, which is on the right in my car when the relay is bolted to the bracket.
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Kaweh
Aug 9, 2015 02:54 PM
