Is the problem just my Tach (stock) or something more??
Old Jun 11, 2009 | 01:47 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
My stock tach always reads more than 7k. When I start up the car the needle goes to the left then back to 7k.
Is the tach broke or is there something else going on??
Here's a vid showin it off -> http://www.youtube.com/watch?v=WjFelxfsDe4
Old Jun 11, 2009 | 04:35 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: Is the problem just my Tach (stock) or something more??
hahaha, cool video, actually I think I seen that on some newer vehicles. does the tach work when the engine is running?
Old Jun 11, 2009 | 07:07 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
The video shows you exactly what it does.
Start the car up, needle moves left then right back over to 7.
Old Jun 11, 2009 | 09:23 PM
Smoke_Jaguar's Avatar
Car: 1986 Camaro T-Top
Engine: 2.8L V6 (MPFI)
Transmission: 5 Speed
Check your gauges, could be a short or a break in the circuit board on the back of the cluster, mine was doing stuff similar.
Old Jun 11, 2009 | 10:05 PM
looks like it's definitely the tach and not something that would effect engine performance. seeing how you have an automatic I don't know how bad you want a tach, but I would really really really want one in my 5 speed if I didn't already have it.
Old Jun 11, 2009 | 10:16 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Resistor in the board on the back of the cluster could also do that to the tach.
Old Jun 12, 2009 | 07:24 AM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
lol Yea I mean its THAT big of a deal since I've been driving like this for 2 years but it would be nice to have everything working properly.
I'll pull out the cluster and take a look it. Someone was selling a cluster for cheap so maybe I'll scoop that up.
Old Jun 12, 2009 | 07:54 AM
you've got the crappy cluster IMO, I like the one I have where all the guages look to be circular. just to make sure look on your coil and check if everything is plugged in. should be 2 harness connectors with 2 wires each.
Old Jun 12, 2009 | 01:16 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
I know many new Pontiacs have gauges that sweep, it almost looks like it's doing that only backwards..
Old Jun 23, 2009 | 11:09 AM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Okay so I got another cluster and now with this one the tach, when the car is idle, sits @ 4-5k, press the gas and it goes pass 7k.
I did notice that one of the contacts that goes in the tach was silver and not gold like the rest. I doubt that could be the problem tho.
Jeremys87
Jul 14, 2022 09:08 PM
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
