Figured it out... kinda
Old Jun 22, 2009 | 05:47 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Alright, i decided to trouble shoot today...
Figured before i go and drop the gas tank and put a new pump in... ($150), it might do some good.
So i pull apart my dash, Found my brain box, i was just gonna cut it out...
then i decided to run all the wires, See if i have a short or something.
Follow a couple wires that ran into the engine bay..
Ones positive to the terminal. Two leading to the siren.
and one that screwed into the fender. Its ground.
Well my car has been sitting for 5 years. And as it turns out, the main food of field mice is wiring.
They had ate through my ground wire. ]
Hope it zapped the bastards...
ran a new ground wire. Fuel pump runs, Getting fuel from the fuel line under the car. (filter wasent on)
so i put my filter back on, and im not getting fuel to the rail.
Any ideas?
thanks in advance, Schwinny.
Old Jun 22, 2009 | 06:30 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Re: Figured it out... kinda
What does the stock fuel line going to the rail look like?
mines rigged...
Old Jun 22, 2009 | 06:51 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
helpful advise, keep one topic to the same thread, i was totally lost until i found your last post. what do you mean by a "rigged" fuel line? if youre getting fuel from the pump to the inlet side of the fuel filter.... couple questions 1. is the fuel filter new? 2. have you visably traced the fuel line from the outlet side of the filter, under the body, up to the fuel rail? you may have a pinch somewhere. get under there and look at it the whole way. it will run along the driver side of the car, next to the brake lines, all the way up to under the engine bay. then the line follows along the frame rail up to the rubber hoses that go to the fuel rail. if it all looks good, my next piece of advise would be to disconnect the line by the rail, and use an air compressor and shoot air all the way thru the line, make sure its not plugged up. make sure that line is clear of any blockage.
then if thats ok, connect the fuel filter, but leave it disconnected from the fuel rail. now make sure you have fuel coming out of the line under the hood. if there is fuel coming out of there, then you have blockage somewhere in the line going to the rail or the rail itself.
Old Jun 22, 2009 | 07:04 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Rigged is someone used a wierd fuel lines, its all split up.
W/e though.
Thanks for the advise.
I may have a bad filter. Its used.
Old Jun 22, 2009 | 07:12 PM
drdave88's Avatar
Engine: 6.0L
definitely start with a filter. thats probably the culprit. if not, then go on from where i said.
Old Jun 22, 2009 | 07:55 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Is there a way to test those things?
Run some water through it?
Old Jun 23, 2009 | 07:02 AM
drdave88's Avatar
Engine: 6.0L
Theyre like $10, just throw a new one on it. That way, even if it doesnt fix it, youve definitely ruled out one issue. and no there really isnt a way to "test" a fuel filter.
Old Jun 23, 2009 | 06:14 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Yeah, Ill throw a new one on.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
db057
Apr 28, 2019 07:45 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
gta892000
Sep 16, 2015 12:37 AM
