Sons 89 firebird 2.8 MPFI
Old Jun 12, 2009 | 06:52 PM
racrx1271's Avatar
I've posted once or twice before but read other posts often and have gotten some excellent information and appreciate everyone's input. My oldest son (18 YOA) talked me into buying an 89 Firebird 2.8 V6 MPFI for his first car. The car ran very rough when we first purchased it, I think it sat for a while unused. Speedometer only reads 65K. I've replaced the heater core, and put new plugs, wires, cap, rotor and the #2 fuel injector harness, that cylinder wasn't firing cause the orig harness was burnt up. The cars runs alot better but still idles a little rough when its put in gear, in park or nuetral it runs better. I'm getting a 12, 23 and 32 code. I have a new oxygen sensor to put in but I'm having a hard time getting the old one out, any suggestions? Also the exhaust needs to be replaced from the cat back which I just ordered and the cooling fans run all the time, the sensor at the back of the passenger side of the engine block is broken and needs to be replaced. The `vacuum hoses arent in great shape but I dont I have any that are leaking. I'm looking for any suggestions to get her running smooth. I think its running rich since my son keeps telling me he smells fuel and he states it bad on MPG, I think some of that is the way he drives.
Old Jun 12, 2009 | 11:35 PM
sienaz 86 2.8's Avatar
Car: 86 firebird
Re: Sons 89 firebird 2.8 MPFI
im sure you looked already but you didnt say hows the airbox (i know mine wasnt happy when a mouse family moved in over the winter )
Old Jun 13, 2009 | 12:03 AM
spimonkey34's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
Transmission: 5 Speed
As far as pulling the old O2, it is easier when it is hot (just don't burn yourself). I have heard of people using torches to heat the exhaust, but I've never had to. Someone else would have to help with that. The auto part stores loan a socket just for O2 sensors, that helps.
Old Jun 18, 2009 | 08:26 AM
racrx1271's Avatar
I can't remember if I changed or checked the air box, I'll take a look. Thx.
Old Jun 18, 2009 | 08:29 AM
racrx1271's Avatar
I cant remember if i changed or checked the air filter, I'll take a look thx.
Old Jun 18, 2009 | 08:34 AM
racrx1271's Avatar
yeah I thought heating it up would work, I'll try driving it for a bit before I use a torch, thx.
Old Jun 18, 2009 | 08:47 AM
sam24th's Avatar
Car: 85 firebird
Engine: 3.4L V6
Transmission: auto
Have you done a full tune up? I remember mines idled bad, but after changing the coolant, trans flush/filter change, and new fuel filter it ran much better. It idles really good now. Oil level might be a lil low might be causing that aswell.
Old Jun 18, 2009 | 04:50 PM
racrx1271's Avatar
I didn't change out the fuel filter, car also dosn't seem to have a fast idle when first started, any ideas?
Old Jun 18, 2009 | 08:38 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
23 is either a bad mat sensor or tps and 32 is EGR stuck open/closed (look it over for vac leaks first). Fix those and it'll run like a peach.
Old Jun 18, 2009 | 09:10 PM
sam24th's Avatar
Car: 85 firebird
Engine: 3.4L V6
Transmission: auto
It might need a coolant flush, thats all my friend's car needed, apparently the original owner put the wrong coolant in it and engine wasnt performing well.
92GTA
Apr 9, 2016 07:39 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
E Rod
Aug 28, 2015 05:17 AM
86IROC112
Aug 21, 2015 07:20 PM
drathaar907
Aug 10, 2015 07:44 AM
