Cold Air Intake Location, Yes or No?
Old Jun 12, 2009 | 11:22 PM
Jared11's Avatar
Car: 1989, Firebird
Engine: 2.8L
Hey there.
I have a cold air intake in my 89 firebird that runs to a hole cut in the engine compartment on the exact opposite side of the battery. (So Passenger side) Which I believe is a spot where most people with cold air'd firebird run theirs. However would it make a difference to have the actual cone filter on the other side of that hole? As of right now it is still inside the engine compartment and sucking air through the 3"+- hole.
Am I at risk of hydro lock if I just extend the air intake through that whole so that the cone filter is on the under side of the cut hole?
Thanks for any help!
Jared
Old Jun 12, 2009 | 11:59 PM
spimonkey34's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
Transmission: 5 Speed
Re: Cold Air Intake Location, Yes or No?
That is exactly my setup. I have run like that for over a year and never had a problem. The advantage is you are getting cooler air. The air in the engine compartment is way too hot. As long as you use a quality filter, like a K&N, not paper, it should be fine.
Old Jun 13, 2009 | 12:07 AM
Stephen's Avatar
Car: 87 GTA
With the filter still in the engine compartment, the amount of cool air coming in, barely offsets the temp of the hot underhood air.
Put you a cone filter on the underside & seal it, so that only cooler air can get to the filter from the outside.
If you can find a way, form a duct to scoop outside air to the new filter location. It will not be Ram Air, but increase the availability of cooler air, vs semi warm, stale air.
Old Jan 20, 2010 | 06:18 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
i just hydro locked, its raining hard and fludded my naborhood about 6 inches on the street, i was doin under 5mph and it slowly killed it, i pull all the plugs and turned it over just fine, havent put the plugs back in yet, but i should be ok, literaly happend 1 hour ago
Old Jan 21, 2010 | 08:10 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
That is where my cold air intake is. I run the largest cone filter that will fit in that space and I removed the fog lights to get more air to the filter. Never had an issue b/c I don't drive through deep water.
Old Jan 21, 2010 | 11:13 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Thats my setup too. I have never had an issue driving through deep water (I avoid it) but I was with my buddy when he hydro locked his '98 Camaro with SLP ram air scoop. We went through about a 6 inch deep puddle when the engine died. He tried to restart it and the starter sheared the bolts off the flywheel!!!
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
