Refilling the block..
Old Jun 27, 2009 | 02:38 PM
legendofkane's Avatar
Car: 1992 CAMARO RS
Engine: 3.1 V6 STOCK
Transmission: AUTO 700R4
I just flushed my 3.1's radiator and block cause it was "burping" antifreeze back in the reserve tank when the engine turned itself off(thinkin tstat was sticking closed and it had air).Now I am gettin a paper gasket(that wasn't on there to begin with) and puttin it all back together,does it make any difference by putting antifreeze in the block and then the radiator,then topping off(with the heater on)?
Old Jun 27, 2009 | 09:03 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Refilling the block..
Not exactly sure what youre getting at by saying "the engine turned itself off". So Im guessing youre saying, the cooling system was flushed (how was it flushed, drain and fill?), give more details on the procedure that happened, and we can help more on this issue. and what do you mean by "the engine turned itself off", that has me at a total loss.
Old Jun 28, 2009 | 12:42 PM
Car: 1992 CAMARO RS
Literally it turned off on its own..maybe a clogged filter..only reading 32 on a pressure gauge,thought maybe it got overheated,didnt run long enough for the fan to come on.I was checking for an oil leak,when it turned off after about 10 minutes with the key still in the on position,had not drained the coolant at all at that time.Thats when I decided it was probably tstat sticking and overheating.
Old Jun 28, 2009 | 01:29 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Ay time that you are pushing fluid into the res. tank, you are either too hot and causing too much pressure in the system, or you have a bad cap. Since you have just refilled the system, I would suggest replacing the radiator cap as well, cheap insurane against another overheat problem, especially with the summer here.
Old Jun 28, 2009 | 07:39 PM
Car: 1992 CAMARO RS
I will try that then since it's probably oem like the tstat,,thanx
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Matt
Jun 26, 2002 12:03 AM
Z28z
Dec 25, 2001 05:41 PM
mefreema
Aug 1, 2001 10:18 AM
Macgyver
Mar 16, 2001 08:55 PM
