Is a 1987 Camaro 2.8 V6 Wire Harness compatible to my 1989 Firebird V6?
Old Aug 20, 2009 | 03:04 AM
89 Firebird V6's Avatar
I wanted to know before I buy it from this guy.
There's also a guy with a 1989 Trans Am trying to sell me his, but I know it's not compatible.
Old Aug 20, 2009 | 08:44 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: Is a 1987 Camaro 2.8 V6 Wire Harness compatible to my 1989 Firebird V6?
Should be the same on all v6 cars from 86-89 .
Old Aug 20, 2009 | 11:54 AM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
I believe you won't have the VATS wiring in the 1987 harness. That is one major difference between the 1987 and 1989.
Old Aug 20, 2009 | 12:00 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
If you need the engine harness then it should work if you need the dash harness I don't remember if 87 had vats or if it is seperate from the dash harness .
Old Aug 20, 2009 | 05:34 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Hold on there. Yes, it will work. Yes, the 89 has VATS (if it has the black pellet in the key). No, if you're putting the 87 harness in the 91, it won't matter, unless you have to rewire the starting circuit in C100. The 89 ECM may have a fuel cut-out circuit controlled by the VATS module that the 87 won't, so you're good there.
No, it's not just a direct bolt-in. You'll need to rewire the TPS, IAC, Oil Pressure Sensor/sender, and possibly the injector harness (different connectors). That's if you don't have to redo the dash harness at C207 and the firewall connector C100. I don't have an 89 FSM handy, so I can't be 100% sure as to how different the 89 harness is.
Zane Story
Oct 8, 2015 12:40 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
okfoz
Sep 22, 2015 03:37 PM
aharvel50
Sep 21, 2015 07:31 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
