Bad fuel pump? HELP!!!!!
Old Aug 28, 2009 | 03:23 PM
vulcanravenxvg's Avatar
Car: 89 RS Camaro
Engine: fuel injected 2.8 6 cyl
Transmission: Automatic
Axle/Gears: Stock crap
the newest headache my 2.8 fuel injected camaro is this... the car will star and run fine most days... but every time (nearly) that i drive the car t get a 1-2000 rpm bog every now and again... the car sometimes gives me trouble starting after i put gas in it but it has always eventually started (knock on wood) when i pump the pedal and excersise 3-4 mins of patience when cranking the car over. i can tell when the car will give me an issue starting because before i crank the motor the fuel gauge pins past full.. after starting the fuel gauge drops to a realistic point. also.... when i begin cranking it starts immediatley but idles like crap and if i give it gas it dies.... then it wont start at all until i pump the pedal and crank and crank and crank... is this the pump? its sporadic and dosnt happen everytime i start the car.. just now and again.
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Newguy91rs
Aug 7, 2015 09:51 PM
