Mechanical Fuel pump
Old Aug 30, 2009 | 12:07 PM
otsego's Avatar
Car: 1991 Pontiac Firebird
Engine: V6 3.1L
Transmission: Automatic
So I rebuilt my motor several years ago. However the block I received has a port for a mechanical fuel pum. I dont think the 1991 3.1L pontiac engines use a mechanical fuel pump. At least according to my Helms service manual they dont.
So I was wondering if you guys could help me figure out what car this engine came from so I can see if they have a block off plate I could buy. I had a steel plate made that has worked good for years but has developed a leak. I'll probably end up reusing it, but it would be nice to know if there are any alternatives and a proper gasket.
Thanks!
Old Aug 30, 2009 | 03:09 PM
mikey88firebird's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8
Transmission: t5
Axle/Gears: not low enough
Re: Mechanical Fuel pump
to the best of my knowledge only the 2.8 from 80-85 in the s10,camaro,firebird,and chevy citation had the mechanical fuel pump, Im not saying you have a 2.8 just that maybe you have a 2.8 block with the 3.1 innards which is of course a 3.1 now. I would go get a used junk fuel pump and have a shop use the base of the pump to make a block off plate that way you can use the fuel pump gasket and that should be effective.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
