Ignition Switch Replacement
Old Sep 12, 2009 | 08:58 AM
masterjc's Avatar
Okiedokie guys, i have a 97 camaro rs that recently had starting issues. When i put my key in, all i get are some accessories like headlights and radio. I don't hear the fuel pump go on and when i put it to the on posistion, nothing happens. To make a long story short, i have outruled the V.A.T.S system because i have a resistor put in place and i was able to basically hotwire it and got it moving for a little while.....only problem with that is that all the power is going to go through the wires and will burn them.....i also would like my key to work correctly soooo, since i know its been used quite a bit (over 82,000 miles) i know that a good possiblility would be the ignition switch. I have checked the wiring many times and checked if everything is getting power when its supposed to be and yes, everything in theory *SHOULD WORK* but there is no power to kick on the fuel pump but the BCM is getting the instructions.....
If anybody has any other imput on this situation please do help. If you would like me to go further on the situation let me know and i can ellaborate on other stuff. otherwise the reason i am posting on this forum is because i wondered if anybody had a guide to replace the ignition switch. Diagrams and wiring schematic would be much appreciated - Thanks!
Old Sep 12, 2009 | 01:45 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Ignition Switch Replacement
did you check the fuel pump relay?
Old Sep 13, 2009 | 10:56 AM
masterjc's Avatar
Yes, i checked all possible solutions regarding fuses and relays with my testlight and some wiring schematics. Everything is working when it should however the problem is that turning the key to on or start doesn't make these things work. That is why the only thing i can think of that can be causing this issue would be the ignition switch. All i think i am going to do is just replace the ignition switch but i can't because i need instructions on going about this. Thanks for the help!
Old Sep 13, 2009 | 11:29 AM
Awesome-X's Avatar
Car: 87 Camaro
Yeah my girlfriend just had this happen on her 95 a few weeks ago, we just installed a push button lol
Old Sep 13, 2009 | 12:24 PM
masterjc's Avatar
Not a bad idea considering i can't move it anywhere right now lol
Old Sep 13, 2009 | 10:00 PM
Awesome-X's Avatar
Car: 87 Camaro
Yeah it worked great for us lol and she likes it more that way. Dunno what was up with the ignition but we still have to have the key in and in the start position to start the car obviously.
Old Sep 16, 2011 | 06:27 PM
SOA_OPIE's Avatar
I also have a question, I bought a steering column for an 89 camaro because I am rebuilding one, the locking plate on the column unlocks with the new key cylindor the problem is when I turn the key back and try to remove it it stays stuck and I cannot remove the key I cant figure out what to do
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
