Wild Pressure
Old Sep 13, 2009 | 08:48 PM
Thing7's Avatar
Car: 1991 Comaro Rs
Engine: 3.1L V6
Transmission: Auto 700R4
Axle/Gears: 10 Bold Stock
Wild Pressure
My oil pressure varies from just above the red to a little over the 60lb mark any idea (the motor was rebuilt 30,000 miles ago)also any ones car die some time whiel driving
Old Sep 13, 2009 | 09:46 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: Wild Pressure
I would venture to say your oil pressure switch is going bad...hence the random readings. cheap and easy fix.
Old Sep 17, 2009 | 10:07 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Wild Pressure
i second the oil pressure switch. as far as the car dying, how does it idle, does it ever stumble on take off or any time at all? need more details on history of upkeep, how it runs normally and what are you doing when it dies; decel, coasting, cruising, etc.
Old Sep 19, 2009 | 12:54 AM
Thing7's Avatar
Car: 1991 Comaro Rs
Engine: 3.1L V6
Re: Wild Pressure
The Car Runs great it's strong doesn't smoke or leak. idle's about 7-8 houndred the vacume lines need to replaced. i've had the car 3 weeks it has died 4 times the last to times it did not wan't to restart but did after the third try all these times I was cruzing about 30mph it has also cut out on the inter state 75mph (it quite pulling for a few seconds then came back)it has this about three times.
db057
Jan 10, 2020 08:55 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Stryker412
Sep 20, 2015 06:59 PM
pacoelrapido
Sep 11, 2015 02:41 PM
