So I sprayed my EGR...
Old Oct 8, 2009 | 09:45 PM
legendofkane's Avatar
Car: 1992 CAMARO RS
Engine: 3.1 V6 STOCK
Transmission: AUTO 700R4
So im lookin for a vac leak on my 3.1 v6 92 camaro,and i hit a spot on the base of my digital egr with some starting fluid and my idle changed(i got a leak)..question is how much effect is leaking blow-by gasses is on an engine on the open road or idle,,thanx guys
Old Oct 9, 2009 | 07:31 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Re: So I sprayed my EGR...
WELL.... its not the leaking gases thats really the problem inless your a tree huger.
If you have a vacuum leak it will cause performance problems though.
Old Oct 9, 2009 | 09:04 PM
Car: 1992 CAMARO RS
Actually i have a rough idle and the car jerks while cruising..im thinkin maybe i need to rebuild my distributor..i know the module checks good(cold at least).From what i remember the pick up coil had corrosion on it,could be causing a whole lot of problems,plugs n wires are a few months old...so...not lookin forward to it since i never rebuilt it before.
Old Oct 10, 2009 | 12:03 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Plugs/wires shouldn't be an issue unless you've fouled the plugs from being overly rich. Fix the vac problem.
Old Oct 10, 2009 | 12:58 PM
Car: 1992 CAMARO RS
i checked the plugs and they are perfect color,i replaced my dizzy cap n rotor,the rotor seemed to have cut into the posts inside the cap,I should have replaced ths icm with a good 1 i had but didnt,,i the car didnt drag to start this time like it had been so i will see what happens when it gets hot and in a few days of runnin.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
db057
Jan 10, 2020 08:55 PM
HoosierinWA
Oct 7, 2015 10:15 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
