88 2.8 V6 non-starter... immobilizer?
Old Oct 16, 2009 | 08:11 AM
Mark from Devon's Avatar
Hi, I have recently bought a 1988 3 Gen with a 2.8 V6 the car turns over but does not start and I have be told this may be because it has an immobilizer that is preventing it from starting... can anyone shed any light on if this could be the case and if so how to rectify the problem? I live in a rural part of Devon in the UK and have no one to ask with experience of these cars.
Mark
Old Oct 16, 2009 | 03:16 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: 88 2.8 V6 non-starter... immobilizer?
Welcome to TGO.org. My guess would be that any type of immobilizer would prevent the starter from working, not just keep the engine from actually starting. Have you done the basic checks such as checking for spark and fuel? That's where I'd start.
Old Oct 16, 2009 | 07:37 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Welcome Mark.
Immobilizers (here) usually just keep the car from being mobile. A boot on the wheel for example. I've never heard of anything that keeps the engine from starting.
Well, if someone bought it from a "buy here, pay here" dealer, and didn't pay their monthly bill, their car would be shut off, but there is usually a big clunky looking electronic device near the ignition. If you don't see one of those, then it likely just needs some basic work done.
Good luck and let us know how it goes.
Old Oct 17, 2009 | 01:28 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Bring built for the 1988 model year, your car did not come factory with a built in anti-theft unit or immobilizer. VATS was used on 1990 and up cars with the 3.1L motor. This system used a resistor in the key to tell the ECM to allow injector pulse when the key was inserted. Very crude and prone to failure, but rest easy, as you do not have this system.
If you have an aftermarket alarm, that may serve a similar function, but 99% of them have a starter interrupt so they don't even crank.
Your problem is most likely due to an ignition or fuel system failure.
Old Oct 17, 2009 | 02:43 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
vats started in 1989. i got a 1989 w/ 2.8L unless the firebirds got it first?
Old Oct 17, 2009 | 06:07 PM
project89's Avatar
my 89 camaro rs also has vats, had problems and had to bypass the system. if u search my user name u should be able to find my post with pictures and directions on how to bypass it.
wen u try to start ur car is there a light on the dash that says security and stays lit?
Old Oct 18, 2009 | 01:10 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
I stand corrected. So there you go. It started in 89, which still means that you shouldn't have the system.
Old Oct 18, 2009 | 02:27 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Sounds like fuel pump. One thing to make sure its not have a friend turn the key to the accel not START IT. just on the on position. Then have you under car near the tank to see if it buzzes a constant sound. IF nothing at all its a fuel pump is what you need.
