Running Rich
Old Oct 18, 2009 | 06:06 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Running Rich
I recently swapped in a 3.4l from a 95 Camaro in my 2.8l Bird. With the engine I installed new (rebuilt) Injectors meant for a 95 Camaro and a new 02 sensor. I used my dads OTC scanner on it while running it'll go in closed loop and run rich while driving. It I idle I get alittle black dust from the exhaust. Also, I get a rich code every once in a while, while idling and while moving.
Is there anything I could do to lean it out? I was thinking pushing the fuel regulater cap out so it gets less pressure. Will that help?
Old Oct 18, 2009 | 09:10 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Running Rich
What's the fuel psi?
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
