Injector Question
Car: 89 Camaro
Engine: 2.8 V6
Axle/Gears: 3.42 open
Injector Question
Alright I just got my camaro and I was wondering where are the injectors on this multi port setup. I'm used to dealing with carbureted stuff so this is new to me. Thanks.
Car: 89 Camaro
Engine: 2.8 V6
Re: Injector Question
that's what i thought so if i take off my upper intake I will see 6 injectors correct? thank you
Car: 86 Firebird SE
Engine: 2.8L
yes remove just the upper intake, the lower does not need to come off, after you move it out of the way, you will see an aluminum log type rail with the injectors coming off of it. This is held on by 2 bolts. I just did an injector swap over the weekend. See "ford injector swap".
Car: 86 Firebird SE
Engine: 2.8L
Well i have an old ultrasonic jewelry cleaner i use. I just give them a bath in mineral spirits while the ultrasonic is on and use a 5v transformer to cycle them while they are in it.
