V8 Speedo in V6
Old Dec 4, 2009 | 07:42 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
V8 Speedo in V6
I have a 88 Firebird v6 with a electric speedo (120mph), Could I use one a V8 140mph Speedo in it?
Old Dec 4, 2009 | 08:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: V8 Speedo in V6
yup, i only believe the tachs are different. The speedos all work off a pulse signal which is not affected by yht engine size.
Only speedo difference would be if the speedo is pre86, then ints mechanical where your 88 is electric
Old Dec 4, 2009 | 09:04 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: V8 Speedo in V6
You will need to swap over 2 parts from your old cluster... The tach and the odometer. Other than that, the cluster just plugs in.
Old Dec 4, 2009 | 10:29 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Re: V8 Speedo in V6
Can't I just put the Speedo in to my own cluster? or is it like hardwired or something?
Theres one at the junkyard I want to get my hands on
Old Dec 5, 2009 | 02:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: V8 Speedo in V6
you can do that, but you still should swap you odometer
Old Dec 7, 2009 | 09:14 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: V8 Speedo in V6
Unless you want to contact the state and get a sticker reporting the actual mileage of the car...
Besides, swapping the odometer is easy enough... Pull the needle, pull out 8 screws and pull the motor out, swap the main assembly, put the motor in, put the screws back in, and put it in the cluster. I think you may need Torx bits for this though.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
