Vacuum
Old Dec 6, 2009 | 10:55 AM
DIPDAVIS's Avatar
Vacuum
I am having issues with loping and surging at lower rpm's, Maybe at higher but can't tell and someone said that I might be having a vacuum leak, 1986 2.8 V6. My vacuum is 15 at idle and drops when throttle opened then recovers slowly. I hear a small whistle sound when I let go of the throttle, need to get a better stethoscope, I can't pinpoint it yet, how do you check the throttle body- MPFI- for leaks and how do you rebuild them can they be?
My mileage is good but inconsistent as with the power or so I believe about the power. i am convinced now that my computer setup is ok and my sensors are doing what they are suppose to.
Old Dec 6, 2009 | 02:00 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: Vacuum
spray some wd-40 in random places with the motor idling. if the rpms surge while in one spot there is the issue.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
