help with this heater valuve
Old Dec 8, 2009 | 01:19 AM
Dfirebird92's Avatar
i just broke my heater vaulve and had it reaplace but now i am stuck i dont know what this vaulve is above the water pump on the v6 3.1 engines and it looks like it is missing a piece to it the water just shoots out for the throttle body i took a pic of it if there is anybody that can help me pls do
Old Dec 8, 2009 | 01:56 AM
RS90CAMARO's Avatar
Re: help with this heater valuve
Here you go, I dont think you can buy the plastic clip seperate I think you have to buy the whole thing. The metal pipe should just clip into the new connector. Any auto parts store should have this it would be in the help section . You coule either use just the clip or replace the whole connector. If you do change the whole connector out be careful they like to break. Also there is a o ring or seal inside the connector where the metal pipe goes to seal it.
http://www.kragen.com/productdetail....tNumber=800401
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
