can my transmission take it
Old Dec 9, 2009 | 01:29 PM
obrien's Avatar
Car: 89 firebird
i have a 1989 firebird 2.8l with a stock transmission in it and i was thinking about swapping in a 1999 grand prix 3.8 supercharged motor in. i was just wondering if i would need a new tranmission. i have gotten alot of suggestions about getting a turbo 350, would that fit that motor? any help would be highly appreciated
-chris
Old Dec 9, 2009 | 02:24 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: can my transmission take it
-chris
you have alot more to worry about with that swap then the trans.
Old Dec 9, 2009 | 02:35 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
0.0 wow yea the trans is the last worry u will have ....GOOD LUCK LOL
Old Dec 9, 2009 | 02:48 PM
madbomber824's Avatar
Car: 1986 Camaro
Engine: 350-Carb
Transmission: 700-R4
u will have to get a new tranny because ur 2.8 tranny will not bolt up to a 3.8 v6. I am pretty sure anyway.
Old Dec 9, 2009 | 02:50 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Thats a FWD engine, you will have to get a trans adapter kit made, so you can use what ever you want.
You can bolt any trans to any engine if you get an adapter.
Old Dec 9, 2009 | 10:25 PM
drewman_93's Avatar
Car: 89 Camaro
Engine: 2.8 V6
Axle/Gears: 3.42 open
where can i get an adapter made? i was thinking of a carbed 350 swap where could i get an adapter to bolt up to my 700r4?
Old Dec 9, 2009 | 11:10 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well pre made ones make sense
You would need a custom made one id bet as it would be easier just
to get a V8 700R4, so id doubt anyone ever made one of those. But if you got cash it can be made.
in the offroad world you will find folks using them allot.
can find dune buggys with anything hanging off the rear of it from a 2.8 to a big old 500 Caddy
Old Dec 9, 2009 | 11:17 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
not to mention that the tq convertor has a different bolt pattern than the small block flexplate has...right?
Old Dec 9, 2009 | 11:21 PM
Car: 1986 Camaro
Engine: 350-Carb
Isn't it just smaller? anyway Yeah ur best bet is just to get a V8 700r4.
Old Dec 10, 2009 | 10:53 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
In general it doesn't matter what bolt pattern or size anything has when you get an adapter kit made. They figure that all in. But a V8 TC will fit a V6 trans n vise versa. Why the V8 guys go after the V6 700 TC from the s10/15 for a cheap way to get a higher stall smaller TC.
But doing all that when its easier to just get a V8 700 is sort of a waste, unless you have some major reason to keep the V6 one.
Old Dec 10, 2009 | 03:39 PM
obrien's Avatar
Car: 89 firebird
ok whatever, forgot its fwd. ill just get a thunderbird 3.8 supercharger. but im still wondering if the my tranny can take it. or what kind should i buy so it wouldnt blow.
Old Dec 10, 2009 | 04:33 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
The Essex is a 90 degree engine, so an adapter would be needed. Probably best to grab the Ford trans too if you go that route.
Seems like a lot of work for 210 hp....
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
