Question about passing smog
Old Mar 20, 2010 | 02:16 AM
uncapj's Avatar
Car: 1987 camaro rs limited
Engine: 2.8 ltr multiport fuel injected
Transmission: th700r
Axle/Gears: 3.43
Ok my camaro sat for 12 years before i bought it from an knuckle head trying to learn how to work on a car very porly ever bolt he touched was hand tigh right down to the 59cent apiece ac delco sparkplugs im sorry but i no they make good ones but these are the cheapo ones
so after i went through and fixed 12 years of half a$$ work and gave the rat in the dash a 30 day notice to vacate the premissus it runs pretty good idles smooth reves fast and returns to idle fast i want to no if it will pass smog i mean i did do a lot of work and ive seen worse on the road but 12 years is a long time
so whats the best way to test a car hot, cold, fresh oil,premium gas, heck il even say additives like the one thats say garenteed to pass smog. just give me the low down
i know i fixed the vacume leakes i went all the way down to the lower intake manifold
and also it has legitimatly 93000 miles on it so its pretty much new will that help my odds
i also herd that there supposed to judge a car by its looks now and fail cars in poor condition that would suck cause the interior still has a lil new car smell and the paint looks like someone scraped the paint off and hit a few shoping carts
Old Mar 20, 2010 | 06:56 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Question about passing smog
1. You're SUPPOSED to run the cheap Delco plugs... R42TS, to be exact. The Rapidfires are junk in our engines.
2. Smog the car hot. Change the oil (and possibly the coolant), fresh gas, replace the filters, full tune-up, INCLUDING the PCV valve.
3. Check again for vacuum leaks, but even more important, exhaust leaks. Also fuel leaks. Replace the gas cap (seals are probably bad).
4. Check the brake lines for leaks, and not just the rubber ones.
5. Properly inflate the tires.
6. Replace the O2S, if you haven't already by the time you reach this, as you don't know if it's been done recently in the car's life or not.
7. If possible, drive the car for a couple of days to allow the engine to get used to running again and be aware of any potential problems (cylinder sealing, for one thing, due to problems with the cylinder walls and rings).
Old Mar 20, 2010 | 07:23 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Replace your CAT and make sure you don't have any leaks...
Old Mar 20, 2010 | 10:36 PM
uncapj's Avatar
Axle/Gears: 3.43
the engine didnt like the cheap plugs it idled bad and missed and had no power so i bought champion platnum plugs and it runs way better and has a little bit of bark i can hit the gas and instantly go to 2500 rpms and it wil go back to idle faster to before the rev was slow and the return to idle was slow to
there cheapo plugs now to thanks to pepboys sale right now the plugs were a buck apeice
Old Mar 20, 2010 | 11:10 PM
uncapj's Avatar
Axle/Gears: 3.43
ive been driving the car for about a month i went easy for a week didnt race the motor just putterd along week two a lil more gas week three drove it regular and this week i released the beast so to speak as for vacume leaks i doubt there are any i replaced any bad hoses and gaskets
and a cat will go bad from sitting? i didnt no that that sucks its almost imposible to find one thats california legal
Old Mar 21, 2010 | 08:56 PM
Engine: 2.7L V6
Axle/Gears: 4.41
No, the cat won't go bad from sitting. From the inside, anyways. Check to make sure it isn't rusted to bits. Also check the AIR injection hose running to the nipple on the side for rust and deteriorated rubber, broken clamps, etc.
With CA emissions, you need to make sure that EVERYTHING is working the way it should and that ALL of the emissions parts are installed and at least SEEM to be in working order. The smog ***** are horrible in CA, from what I've heard. If you do fail the sniffer test, post up the results and we can tell you what to do about it. Check ALL of the vacuum hoses, not just the ones that LOOK bad. If you touch one and it leaves a good amount of rubber on your fingers, well, that one needs to be replaced as well. Don't forget the fuel vapor hoses leading to the vapor canister, either, as those can rot just as easily at the others, and add to the HC score.
onefreakz
May 14, 2018 12:15 PM
kairles
Oct 26, 2015 09:13 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
g.l.mos
Aug 22, 2015 12:02 AM
redmaroz
Aug 16, 2015 11:40 PM
