fuel line question
Old Mar 23, 2010 | 08:46 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
fuel line question
is there any other option to using the metal lines that connect to the fuel rail? im going to have to make new metal fuel lines to work with the 3.4 intake and wasnt sure if there was a easier way. wish i had kept that 3.4 fuel rail would make it a bit easier as well
Old Mar 31, 2010 | 11:20 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: fuel line question
You could use the screw in fitting on the fuel rail, cut it with a tube cutter, leaving like a couple inches to give enough room to get a rubber hose line on it with some hose clamps and just run that all the way to the metal section coming up from the fuel tank.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
