no spark
Old Apr 13, 2010 | 04:12 PM
kamarrow89's Avatar
no spark
just bought a 89 camaro rs 2.8 has no spark just wondering what is the most common problem that i should check im gonna do cap and rotor and ignition modual but if it still has no spark then what just asking ahead of time . i just want to get it running till i drop in the big boy
Old Apr 13, 2010 | 05:02 PM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Re: no spark
I'm not sure if the 2.8 has this, but the condenser in the distributor can go bad leading to no spark. This happened on a brand new Mallory distributor I bought. It was the last possible thing that could've gone bad, and it did. Check for continuity across the condenser when you replace the ignition module, just to be sure.
Old Apr 13, 2010 | 06:45 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: no spark
Um, Delco HEI systems stopped using condensers and points back in the 70's...
OP, I'll bet the ignition module inside the distributor is shot. Either that, or there is a broken wire between the ignition coil and the module (or disconnected wire).
Old Apr 13, 2010 | 07:51 PM
plasmeh's Avatar
Car: 1986 IROC-Z
Re: no spark
As I said, I wasn't sure.
Old Apr 14, 2010 | 09:31 AM
kamarrow89's Avatar
Re: no spark
i will check it when i get off work tonight thanx i'll keep you posted
Old Apr 19, 2010 | 09:10 AM
kamarrow89's Avatar
Re: no spark
awsome it runs . i just changed the cap and rotor . not bad for a $500 car and 55 to get it running
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
