1991 Firebird 3.1L V6 Auto to T5 Manual
Old Apr 21, 2010 | 06:55 AM
Gate's Avatar
What do I need? And need to do?
Old Apr 21, 2010 | 09:36 AM
project89's Avatar
Re: 1991 Firebird 3.1L V6 Auto to T5 Manual
u will need to get the parts from a donor car
i.e
bellhousing
transmission
trans corssmember and mount
u will need the prom out of the 5 speed car as well
clutch hydralics
and the peddel assembly
Old Apr 21, 2010 | 01:12 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
i.e
bellhousing
transmission
clutch hydralics
This is a good start. However, you won't need the crossmember and trans mount as the ones you have will bolt right in (and the mounts for the manual crossmember are INSANELY expensive compared to $20 for the other one). However, you DO need the torque arm insulator that holds the arm to the tail of the trans. This should probably be bought new, or tell the guy in the yard you need everything that goes with the trans including this mount.
You probably won't find a 5-speed MEMCAL for your car either, as most of the ones in the yards are more than likely older cars that don't use a MEMCAL. And the ones in FWD vehicles won't work as the ignition tables are WAY off.
Someone forgot that you also need the flywheel and clutch. Without those, you're not going anywhere soon. The flywheel MUST be for an internally balanced engine or you're going to shake the car apart.
:edit: While the trans is out, also replace the rear main seal and rear cam seal. You don't want one of these to be bad and spit oil all over your clutch, especially if you don't already know how to drive a manual trans.
rubblerubble
Mar 13, 2016 06:57 PM
Joe2002
Theoretical and Street Racing
Oct 4, 2002 10:27 PM
GofasterFirebird
Sep 2, 2001 04:09 PM
Gwen77
Aug 17, 2001 02:21 PM
