windshield wiper gremlin
Old May 10, 2010 | 10:30 PM
purple98haz28's Avatar
just recently i have been having a problem with my winshield wipers... if you turn the wipers on by any means i mean fast slow or single wipe or wash they stay on and will not turn off until the switch is turned to off and the car is turned off and restarted... what gives this is very annoying when it just mists or drizzles
Old May 11, 2010 | 03:56 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: windshield wiper gremlin
This is probably better posted in the electronics section. If I had to guess though, the pulse module is messed up. That's what's going on with mine.
Old May 14, 2010 | 05:58 PM
where is the pulse modulator... have never heard of it. any help in appreciated
Old May 14, 2010 | 09:25 PM
moderator if this is best moved can you please do that
Old May 15, 2010 | 08:52 AM
ok after much research and pulling the cover to fined the blue arm broken off i have come to the conculsion i need a wiper modulator/circuit board for a 85 camaro. i have not been able to find one where to find one. also the spray does not work im assuming its all related. WHERE CAN I BUY A MODULATOR
Old May 15, 2010 | 08:18 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I believe it's called a pulse module, and I also believe that the only way to get one nowadays is to replace the entire wiper motor. Look on eBay or even from Rock Auto. eBay will, more than likely, have a few motors available, but they're used. Rock Auto MAY have just the pulse module, but I wouldn't count on it, but either way, the parts will either be new or remanufactured. Take that as you will as some reman parts aren't worth even what you would pay for the cores...
Old May 15, 2010 | 10:20 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
RA does have pulse motors, but you'd have better luck getting a working used one.
ACDelco part #22122525
codeysabatini
Nov 10, 2015 04:07 PM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
