Suggestions for spark plug wires?!!!!
Old May 15, 2010 | 10:24 AM
89v6firebird's Avatar
Car: 89 firebird (v6) T-top.
Engine: v6 EFI
Transmission: IDK
Axle/Gears: IDK
I was tweeking somethings today, cause the bird was't running properly and noticed that one of the wires was partially severed, near the boot. probably my fault and the fact that there old. So before I go and drop money on new wires, what are the the best in your opinion?
-When you put your spark plugs in, do you figure out the gap? is there a way to do that? My buddy said a reason for the bird not running right is because it could be the gap is too small or big, with the plugs?
Old May 15, 2010 | 11:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Suggestions for spark plug wires?!!!!
Check set the plug gaps with a gapping tool. Older style are a set of steel wires with a 90* bend at the end. These are pulled through the gap to check it. The gap being adjusted manually by various means.
There is also a coin style gap checker. Has a tapered ramp around the perimeter. Place it in the gap and rotate until it fills the gap. Read the dimension off the tool (it is numbered toward the inside of the ramp).
Proper plug gap can be found under hood on the emissions sticker.
For wires I've been using the Borg Warner Select series. These are a good spiral wound wire with a silicone jacket. I know that pep-boys carries them. But I think that NAPA also carries them. Reasonably priced too.
RBob.
Old May 15, 2010 | 11:59 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
bosch wires seem to be pretty good. i also run duralast wire which are guaranteed forever but i was doing a tune up on a honda accord and got 2 bad wires. they replaced them.
Old May 15, 2010 | 02:14 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
+1 for the Bosch. Have a lifetime warrenty so if anything goes wrong I'll get new opnes for free. I was just gonna get some Duralast from AZ but they were out, so they upgraded me to Bosch for free
Old May 15, 2010 | 03:26 PM
Engine: v6 EFI
Transmission: IDK
Axle/Gears: IDK
Yea I bought some Bosch. one question, what is the spark plug that is not attatched to the engine? The extra wire, that goes from the distributer to the extra spark plug? Whats that for? A ground?
Old May 15, 2010 | 04:32 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
You mean the one that runs from the middle of the cap? That would be the ignition coil that it connects too.
Old May 16, 2010 | 08:22 AM
Engine: v6 EFI
Transmission: IDK
Axle/Gears: IDK
Yea that. its all carroted and ****. is there a way to replace that too? it might have to do with why its hard to start the car after its been running?
Old May 16, 2010 | 08:35 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
yes you can replace the coil, and a new set of plu wires should come with one that ges from the coil to cap.
Old May 16, 2010 | 08:39 AM
Engine: v6 EFI
Transmission: IDK
Axle/Gears: IDK
Ok Kool. yea I relplaced the wire, thats when I noticed all the carossion on it.
Old May 17, 2010 | 01:08 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Get Taylor 8mm wires from Summit racing. Much better than stock...
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
