F1ZE injector swap problem
Old Jun 1, 2010 | 08:18 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Well i finally got my injectors put in today but noticed two of em i could still see the o-ring at the bottom and the others weren't visible like it sits flush with where they go in.Will it be ok like this? I accidentally broke one of the retainer clips too so i need to get a new one.
Old Jun 1, 2010 | 09:41 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
Re: F1ZE injector swap problem
If you got the old Bosch style like out of a Bronco II or a Ranger, then no, the O-rings must seat down into the manifold completely. You must lube the O-rings before installation or they will not seat right.
Old Jun 3, 2010 | 08:25 PM
Car: 1988 camaro
Engine: cammed 3.1
I found the problem they all seat the o-ring is no longer visible I didn't tighten a screw from the middle manifold and it wasn't letting the fuel rail seat properly will probably have it running tomorrow had to order a new thermostat housing because I cracked it when I was replacing the thermostat.
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
sreZ28
Aug 14, 2015 07:48 PM
