Low Oil Prssure
Old Jun 5, 2010 | 03:44 PM
88BirdChief's Avatar
Car: 88 Firebird
Engine: 2.8
Low Oil Prssure
So I am out for a drive yesterday and I notice my oil pressure down to almost nothing at stop lights/signs. It usually goes down but not that far and then when I get back on the gas it goes up to the mid way point. So I jump on the Highway and the gauge wont climb above 20PSI.
What could be causing this? Is it and easy fix that I can do myself?
Thanks Steve
Old Jun 5, 2010 | 03:54 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Low Oil Prssure
Check the oil pressure sender by the oil filter... Has either 2 or 3 wires. If your oil pressure was actually that low, your engine would be knocking at idle. It could also be a worn out factory gauge.
Old Jun 5, 2010 | 04:13 PM
Car: 88 Firebird
Engine: 2.8
Re: Low Oil Prssure
well it aint knocking so maybe its the gauge itself...dunno...how can I check the gauge to tell or should I just take it in to be looked at?
Old Jun 5, 2010 | 05:24 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Low Oil Prssure
Resistance-type gauges are tested using a special box with 3 different adjustable resistors inside, which I doubt you have. You could go to a dealer or someplace to have it tested, but it won't be cheap.
my86bird
Oct 23, 2015 12:20 PM
Prodigious
Oct 4, 2015 11:20 PM
mddaniel
Sep 8, 2015 05:16 PM
RyanJB
Sep 2, 2015 01:27 PM
Navy8125
Aug 21, 2015 09:32 AM
