89 firebird 2.8 still wont start
Old Jun 8, 2010 | 09:12 PM
racrx1271's Avatar
Car cranks but wont start, has spark. Jumped the fuel pump and could here it hum, after jumping the pump the car will start for a second then quit. When I turn the ignition on I don't here the pump hum. What should I check next? Any Ideas would be helpful.
Based on some previous replies I changed the oil pressure switch (it was leaking) checked the fusible link (had continuity, its good) changed the fuel filter and changed the relay. Still wont start. I dont have a fuel pressure tester but fuel at the schrader valve. the strangest thing is that I no longer have a check engine light so I cant check codes, I'm pretty sure its not the bulb since it was on before, dont want to pull instrument cluster to confirm. Any ideas or suggestions would be really appreciated.
Thanks Rob
Old Jun 8, 2010 | 09:45 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: 89 firebird 2.8 still wont start
just becuase the pump turns on and gives you fuel at the valve doesnt mean that it couldnt still be bad, how much pressure are you getting at the vavle and while its running would be helpful to know
Old Jun 9, 2010 | 06:25 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Did you replace the right relay? Did you check the ECM for a code 54?
Check to make sure you have power at the inline fuse on the frame rail with the orange and red wires, as this feeds both the fuel pump and the ECM. Also, check the ECM IGN fuse under the dash. Set the car up to test for codes. If the radiator fan turns on, the ECM is getting power and the SES light bulb is dead.
Old Jun 9, 2010 | 10:37 PM
TheMightyBigE's Avatar
Car: 1986 Camaro Berlinetta
Engine: 2.8L Multi-Port Fuel Injected
I had a similar problem with my 86 camaro not to long ago. After replaced several other parts with no success I checked the spark plugs. I replaced the spark plugs and wires and she fired right up without a problem. So I'd try that, hope it helps.
Old Nov 16, 2010 | 11:15 PM
Josiah.'s Avatar
I am having the same problem. I replaced my spark plugs my distributor my rotor and the spark plug wires and the unit under my distributor. And my fuel pump and just re did my exhaust, the belts turn but it wont start up. it is getting proper fuel pressure and has no check engine lights. and I am not getting any codes, so......
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
86Base
Aug 8, 2015 01:34 PM
