Fuel relay keeps blowing
Old Jun 14, 2010 | 09:25 PM
belialsson's Avatar
i have the 2.8l mpfi and i am having issues with it blowing the fuel relay... it will start the first time on the relay but after i turn it off it won't fire again. Any suggestions?
Old Jun 15, 2010 | 08:06 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Fuel relay keeps blowing
try replaceing the relay should be about 20 bux or so.
Old Jun 15, 2010 | 10:27 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check the wiring at the bottom of the connector. If it's like mine was, the wires are shorting together and causing headaches. Go to a place that sells alarm or security systems for cars and see if you can't pick up a relay and connector. That's what I currently have mine running on (well, when the harness is installed, anyways) along with the fan relay (dual relay block, using both relays in the block).
It's either that or the fuel pump is drawing too much current through the relay. Have the current draw checked if you can't do it yourself.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
