Injectors vs. HP
Old Jun 30, 2010 | 12:14 AM
nezzie09's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
Injectors vs. HP
What size of injectors are needed for what range of horsepower?
As in, what kind of HP can I have with 15 lb injectors, 19 lb, etc…?
Old Jun 30, 2010 | 12:26 AM
project89's Avatar
Re: Injectors vs. HP
a general rule of thumb is like this
15# = 150 hp na
19# = 190 hp na
21# = 210 hp na etc etc etc
na its actually a lil higher rating but it works for a general idea
fr turbo and supercharged engines it would be slightly lower since they need to run a lwer afr so say the 15# would be around 130 hp turbo/superchared
Old Jun 30, 2010 | 12:41 AM
nezzie09's Avatar
Engine: 2.8 MPFI
15# = 150 hp na
19# = 190 hp na
So basically…*10 hp per lb?
And for a turbocharged engine, do I basically subtract 20 hp off the n/a rating?
15# = 130 hp
19# = 170 hp
21# = 190 hp
etc…
Thanks for the help..
Old Jun 30, 2010 | 12:52 AM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
remember, just because u replace ur injectors with higher presure ones dsnt mean ur hp will go up. if ur engine dsnt require that much pressure, ur gonna end up flooding ur engine with gas n will run crapy
Old Jun 30, 2010 | 10:01 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Yeah, it will only go up so much, then start to drop off. You dont wanna run too rich. I wouldnt recommend going up much, search for the article about replacing your injectors with ford 2.9L injectors. that seems to be the way to go.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
3.8TransAM
Sep 17, 2015 02:16 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
