carb backfiring?
Old Jul 4, 2010 | 08:49 PM
84olmpcboy's Avatar
Car: 84 olympic edition camaro
Engine: 2.8
carb backfiring?
I swaped carbs the other night and when I put the new one on I heard a pinging sound, after a while of letting it run it ran perfect. After about 60miles it started backfiring like crazy through the carb at about half throtle. It started all at once without warning. It idles fine. I replaced the mixture control selenoid seal and tested the selenoid and it worked fine and I also tore the carb apart and cleaned it very throughly. Any suggestions would be appreciated?
Old Jul 5, 2010 | 06:24 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: carb backfiring?
Check the ignition timing...
Old Jul 15, 2010 | 09:58 PM
84olmpcboy's Avatar
Engine: 2.8
checked the timing and it was dead on. I'm goin to check all the plugs and wires tomorrow, right now I'm thinking that maby a valve bent?
Old Jul 16, 2010 | 10:37 PM
84olmpcboy's Avatar
Engine: 2.8
found out what it was. Something went down the intake and into the cylinder it messed up the spark plug but compression and everything else was good so it was a $2.00 fix ya'll can delete this post if you want thanks
85 Jimmy
Sep 30, 2015 07:56 AM
Damon
Sep 26, 2015 04:29 PM
lanceflame44
Sep 25, 2015 12:28 PM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
