What is this part?
Old Aug 14, 2010 | 02:05 PM
rocky165's Avatar
Car: 88 camaro sc-bought in california
Engine: 2.8l v6
Transmission: automatic
What is this part?
I broke the little plastic tube off changing spark plugs.
Old Aug 14, 2010 | 02:37 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: What is this part?
Looks a bit like a EGR vacuum solenoid.
Old Aug 14, 2010 | 04:59 PM
Heavy_Chevy's Avatar
the guy that had my camaro befor did the same thing and that solenoid is 210 dollars at autozone....i put a t in the other line going to that same "nipple" and used some hard plastic and a torch to drip it into the hole to close it off from leaking....just hooked that one up into a t unless you have a local scrap yard to get one from for cheap that's all i could see to do to it sinve i just want to get it running before i drop any major paper into it.
Old Aug 14, 2010 | 10:31 PM
rocky165's Avatar
Engine: 2.8l v6
Thanks Guys,I think I will try the t method.WOW $210 bucks!!!
BTW will this leak cause it to run rough?I put in new plugs,wires,distributor and rotor.It runs better,but when accellerating from a dead stop it kind of boggs down with no power until it gets going.
Old Aug 15, 2010 | 06:51 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Yes, breaking that line can cause a leak. However, that would also mean that the solenoid is sticking open, in which case it needs to be replaced anyways, since opening the throttle plate is what sends the vacuum signal to the solenoid. And yes, the factory, on some cars, had the solenoid set up with a T in the upper line running to the valve from the solenoid, instead of the dual nipple at the solenoid outlet.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
